跳转到主内容
Disassembling HP Envy TouchSmart 15 Back Plate
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. Disassembling HP Envy TouchSmart 15 Back Plate, Battery: 步骤 1 中的图像 1,1
    • Press the battery release tab and the battery will pop up.
  2. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 2 中的图像 1,1
    • Remove the battery from the laptop, it will come out easily.
  3. Disassembling HP Envy TouchSmart 15 Back Plate, Accessory Plate: 步骤 3 中的图像 1,2 Disassembling HP Envy TouchSmart 15 Back Plate, Accessory Plate: 步骤 3 中的图像 2,2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 4 中的图像 1,3 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 4 中的图像 2,3 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 4 中的图像 3,3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. Disassembling HP Envy TouchSmart 15 Back Plate, Solid State Drive: 步骤 5 中的图像 1,2 Disassembling HP Envy TouchSmart 15 Back Plate, Solid State Drive: 步骤 5 中的图像 2,2
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 6 中的图像 1,2 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 6 中的图像 2,2
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
  7. Disassembling HP Envy TouchSmart 15 Back Plate, Hard Drive: 步骤 7 中的图像 1,2 Disassembling HP Envy TouchSmart 15 Back Plate, Hard Drive: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  8. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 8 中的图像 1,2 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 8 中的图像 2,2
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
  9. Disassembling HP Envy TouchSmart 15 Back Plate, Back Plate: 步骤 9 中的图像 1,3 Disassembling HP Envy TouchSmart 15 Back Plate, Back Plate: 步骤 9 中的图像 2,3 Disassembling HP Envy TouchSmart 15 Back Plate, Back Plate: 步骤 9 中的图像 3,3
    • Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
  10. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 10 中的图像 1,3 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 10 中的图像 2,3 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 10 中的图像 3,3
    • Remove plastic cover highlighted. It should expose a screw that you will need in a later step.
  11. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 11 中的图像 1,1
    • Remove all highlighted screws with PH 1 screwdriver. These screws are PM 2.0x2.5.
  12. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 12 中的图像 1,2 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 12 中的图像 2,2
    • Remove all highlighted screws from the battery access area. These are PM 1.5x2.0 screws
  13. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 13 中的图像 1,1
    • Remove screws highlighted with PH1 screwdriver from accessory plate area.These are PM 2.5x3.0 screws
    • Remove screws highlighted with PH1 screwdriver from accessory plate area. These are PM 2.5x4.5 screws
  14. Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 14 中的图像 1,3 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 14 中的图像 2,3 Disassembling HP Envy TouchSmart 15 Back Plate: 步骤 14 中的图像 3,3
    • Pry open back plate area with plastic opening tool. The back plate should pry open with relative ease. If you feel some resistance at any point please refer to steps 2-5 because a screw has probably been missed.
结论
Ramon Villadonga
于09/04/15注册
1,035 声望
创作了5篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 71
