跳转到主内容
HP Deskjet F4480 Top Lid Replacement
你所需要的
  1. HP Deskjet F4480 Top Lid Replacement, Open front access panel: 步骤 1 中的图像 1,1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Top Lid Replacement, Top Lid: 步骤 2 中的图像 1,1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Top Lid Replacement: 步骤 3 中的图像 1,3 HP Deskjet F4480 Top Lid Replacement: 步骤 3 中的图像 2,3 HP Deskjet F4480 Top Lid Replacement: 步骤 3 中的图像 3,3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Top Lid Replacement: 步骤 4 中的图像 1,2 HP Deskjet F4480 Top Lid Replacement: 步骤 4 中的图像 2,2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Top Lid Replacement: 步骤 5 中的图像 1,3 HP Deskjet F4480 Top Lid Replacement: 步骤 5 中的图像 2,3 HP Deskjet F4480 Top Lid Replacement: 步骤 5 中的图像 3,3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
结论
21等其他人完成本指南。
Tim
于01/15/13注册
184 声望
创作了4篇指南
团队
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G35
5 名成员
创作了15篇指南
一条评论
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 20
总计 9,530
