跳转到主内容
Disassembling HP Compaq dx2000MT Hard Drive
你所需要的
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: 步骤 1 中的图像 1,1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 2 中的图像 1,2 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 2 中的图像 2,2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 3 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 3 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 3 中的图像 3,3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 4 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 4 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 4 中的图像 3,3
    • Once again, this may take considerable force.
    it’s useless my friends
    bisous sur les fesses de ta mamaa
    Albert einstein - 回复
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 3,3
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 6 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 6 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 6 中的图像 3,3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
    retirar la mascara frontal .
    Salvador Aranda - 回复
  7. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 7 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 7 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 7 中的图像 3,3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 8 中的图像 1,2 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 8 中的图像 2,2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 9 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 9 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 9 中的图像 3,3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 10 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 10 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 10 中的图像 3,3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 11 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 11 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 11 中的图像 3,3
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 12 中的图像 1,2 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 12 中的图像 2,2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
    Retire el disco duro de la caja del disco duro tirandoempujando hacia adelante de la caja .
结论
4等其他人完成本指南。
Eva Pong
于09/22/11注册
101 声望
撰写一个指南
团队
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G16
4 名成员
创作了17篇指南
2条评论
can i upgrade it to 500gb?
connor gouws - 回复
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
Thomas Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 49
总计 8,251
