跳转到主内容
加入维修社区 - 创建账户
Disassembling HP Compaq dx2000MT Hard Drive
你所需要的
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: 步骤 1 中的图像 1,1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 2 中的图像 1,2 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 2 中的图像 2,2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 3 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 3 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 3 中的图像 3,3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 4 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 4 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 4 中的图像 3,3
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 3,3
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 6 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 6 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 6 中的图像 3,3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 7 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 7 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 7 中的图像 3,3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 8 中的图像 1,2 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 8 中的图像 2,2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 9 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 9 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 9 中的图像 3,3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 10 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 10 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 10 中的图像 3,3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 11 中的图像 1,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 11 中的图像 2,3 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 11 中的图像 3,3
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: 步骤 12 中的图像 1,2 Disassembling HP Compaq dx2000MT Hard Drive: 步骤 12 中的图像 2,2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
结论
4等其他人完成本指南。
Eva Pong
于09/22/11注册
101 声望
撰写一个指南
团队
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G16
4 名成员
创作了17篇指南
2指南评论
can i upgrade it to 500gb?
connor gouws - 回复 分享
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
ThosD - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 120
总计 9,829
