跳转到主内容
Disassembling General Electric Telephone 2-9710A Handset
你所需要的
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: 步骤 1 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: 步骤 1 中的图像 2,2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: 步骤 2 中的图像 1,3 Disassembling General Electric Telephone 2-9710A Handset: 步骤 2 中的图像 2,3 Disassembling General Electric Telephone 2-9710A Handset: 步骤 2 中的图像 3,3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: 步骤 3 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: 步骤 3 中的图像 2,2
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: 步骤 4 中的图像 1,1
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: 步骤 5 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Handset: 步骤 5 中的图像 2,2
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: 步骤 6 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Handset: 步骤 6 中的图像 2,2
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: 步骤 7 中的图像 1,1
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: 步骤 8 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Handset: 步骤 8 中的图像 2,2
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: 步骤 9 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Handset: 步骤 9 中的图像 2,2
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: 步骤 10 中的图像 1,1
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
结论
Alles Rebel
于09/20/12注册
72 声望
创作了3篇指南
团队
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G59
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 2,748
