当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unplug the device before proceeding.
Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
To release the cable, gently press down on the top plastic tab of the connector.
Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
Slide the door off of the battery compartment.
Remove the battery from the phone.
Ensure the phone is unplugged from the phone jack and the electrical source.
Locate the volume dial on the right side of the telephone.
Remove the volume dial by gently grasping it and pulling it away from the base.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
