跳转到主内容
Disassembling General Electric Telephone 2-9710A Base Shell
你所需要的
  1. Disassembling General Electric Telephone 2-9710A Base Shell, Phone Cord: 步骤 1 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Base Shell, Phone Cord: 步骤 1 中的图像 2,2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Base Shell: 步骤 2 中的图像 1,3 Disassembling General Electric Telephone 2-9710A Base Shell: 步骤 2 中的图像 2,3 Disassembling General Electric Telephone 2-9710A Base Shell: 步骤 2 中的图像 3,3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Base Shell, 9V Base Battery: 步骤 3 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Base Shell, 9V Base Battery: 步骤 3 中的图像 2,2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Disassembling General Electric Telephone 2-9710A Base Shell, Remove Volume Dial: 步骤 4 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Base Shell, Remove Volume Dial: 步骤 4 中的图像 2,2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Disassembling General Electric Telephone 2-9710A Base Shell, Remove Screws on the Back: 步骤 5 中的图像 1,1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Disassembling General Electric Telephone 2-9710A Base Shell, Pry the Back Off: 步骤 6 中的图像 1,2 Disassembling General Electric Telephone 2-9710A Base Shell, Pry the Back Off: 步骤 6 中的图像 2,2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
结论
Reassemble your devise by following these instructions in reverse order.
Alles Rebel
于09/20/12注册
72 声望
创作了3篇指南
团队
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G59
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 779
