跳转到主内容
Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case
你所需要的
  1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: 步骤 1 中的图像 1,1
    • Unplug the toaster from the electrical outlet.
  2. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: 步骤 2 中的图像 1,2 Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: 步骤 2 中的图像 2,2
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: 步骤 3 中的图像 1,1
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
结论
Ron Gajdos
于10/16/13注册
307 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 的会员
UMASSD-VIJAYBHASKAR-F13S4G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,088
