当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
Once the tool is inserted it can slide around the entire device.
Remove four small T5 torx screws.
Be gentle, the screws are easily stripped.
Lift cover off of unit.
Be careful not to lose small rubber piece on the bottom right corner.
Disconnect ribbon cable from logic board.
Remove two T5 torx screws holding down logic board.
Disconnect battery.
Gently lift the logic board out of the unit
Be careful not to damage the battery connector on the top of the unit.
取消:我没有完成这个指南。
6等其他人完成本指南。
与1其他贡献者
于11/28/10注册
206 声望
撰写一个指南
徽章: 8
+ 5更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 5,233
