跳转到主内容
Disassembling Garmin Nuvi 1200 Logic Board
你所需要的
  1. Disassembling Garmin Nuvi 1200 Logic Board, Logic Board: 步骤 1 中的图像 1,1
    • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
  2. Disassembling Garmin Nuvi 1200 Logic Board: 步骤 2 中的图像 1,1
    • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
  3. Disassembling Garmin Nuvi 1200 Logic Board: 步骤 3 中的图像 1,2 Disassembling Garmin Nuvi 1200 Logic Board: 步骤 3 中的图像 2,2
    • Lift cover off of unit.
    • Be careful not to lose small rubber piece on the bottom right corner.
  4. Disassembling Garmin Nuvi 1200 Logic Board: 步骤 4 中的图像 1,1
    • Disconnect ribbon cable from logic board.
  5. Disassembling Garmin Nuvi 1200 Logic Board: 步骤 5 中的图像 1,1
    • Remove two T5 torx screws holding down logic board.
    • Disconnect battery.
  6. Disassembling Garmin Nuvi 1200 Logic Board: 步骤 6 中的图像 1,1
    • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
结论
6等其他人完成本指南。
Zachary Landau
于11/28/10注册
206 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 5,241
