跳转到主内容
Disassembling Fujifilm Endeavor 100ix Outer Casing
你所需要的
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: 步骤 1 中的图像 1,1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 2 中的图像 1,1
    • Locate the battery door.
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 3 中的图像 1,1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 4 中的图像 1,1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 5 中的图像 1,1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 6 中的图像 1,2 Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 6 中的图像 2,2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 7 中的图像 1,1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 8 中的图像 1,1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 9 中的图像 1,1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 10 中的图像 1,1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 11 中的图像 1,2 Disassembling Fujifilm Endeavor 100ix Outer Casing: 步骤 11 中的图像 2,2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
结论
Eric Nicolai
于01/10/11注册
679 声望
创作了6篇指南
团队
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G5
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,357
