跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Removing the outer case of the camera.
配件
没有特定配件。
  1. Remove the batteries from the camera to prevent danger of electric shock.
    • Remove the batteries from the camera to prevent danger of electric shock.
  2. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws.
    • Locate all five screws on the camera. Then proceed to remove all the screws.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • If your screwdriver does not fit, or you do not have the proper one, you can use a hot glue gun to fix the screwdriver to the head of the screw. Wait for it to harden slightly, and then try to remove the screws.
  5. Remove outer case.  Pull the back away from the main body of the camera. Remove outer case.  Pull the back away from the main body of the camera.
    • Remove outer case. Pull the back away from the main body of the camera.
结论
Cody
于2010年04月18日注册
47 信誉积分
创作了4篇指南
团队
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G11
3 名成员
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,430
