跳转到主内容
加入维修社区 - 创建账户
Disassembling Flashlight Light Bulb Components
  1. Disassembling Flashlight Light Bulb Components, Disassembling Flashlight Light Bulb Components: 步骤 1 中的图像 1,2 Disassembling Flashlight Light Bulb Components, Disassembling Flashlight Light Bulb Components: 步骤 1 中的图像 2,2
    • The translucent flashlight before reverse analysis.
    • Twist the light components(red circle) counterclockwise while holding the body of the flashlight (black circle).
    询问修复机器人
    添加评论
  2. Disassembling Flashlight Light Bulb Components: 步骤 2 中的图像 1,3 Disassembling Flashlight Light Bulb Components: 步骤 2 中的图像 2,3 Disassembling Flashlight Light Bulb Components: 步骤 2 中的图像 3,3
    • When removing light component, the black rubber band (red circle) separating body and head falls off. Turn black socket (black circle), which connects bulb to batteries, counterclockwise and disconnect.
    • Bulb (red circle) simply pulled out reflector and lens compartment.
    • The metal connector (red circle) easily slides out open end when twisting off the black socket. This metal piece connects the metal switch supplying power to the bulb.
    询问修复机器人
    添加评论
  3. Disassembling Flashlight Light Bulb Components: 步骤 3 中的图像 1,2 Disassembling Flashlight Light Bulb Components: 步骤 3 中的图像 2,2
    • The lens connected to the head of the flashlight comes apart using one thumb/finger. Using two other fingers to hold the head's base, the third thumb/finger pushes the lens in the opposite direction with a force >5N.
    • The remaining lens and light reflector component (red circle) of the flashlight pops out of the unit and separates. Simultaneously, the translucent skin (black circle) attached to the head of the flashlight peels off using hands.
    询问修复机器人
    添加评论
  4. Disassembling Flashlight Light Bulb Components: 步骤 4 中的图像 1,1
    • The complete light bulb component disassembly.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G18
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 38
过去 30 天: 144
总计 6,449
