跳转到主内容
加入维修社区 - 创建账户
Disassembling Ericsson CF 388 Phone Casing
你所需要的
  1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 1,3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 2,3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 3,3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: 步骤 2 中的图像 1,3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: 步骤 2 中的图像 2,3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: 步骤 2 中的图像 3,3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Phone Casing: 步骤 3 中的图像 1,3 Disassembling Ericsson CF 388 Phone Casing: 步骤 3 中的图像 2,3 Disassembling Ericsson CF 388 Phone Casing: 步骤 3 中的图像 3,3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Phone Casing: 步骤 4 中的图像 1,2 Disassembling Ericsson CF 388 Phone Casing: 步骤 4 中的图像 2,2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
结论
2等其他人完成本指南。
Niccolas Tones
于03/09/12注册
60 声望
创作了9篇指南
团队
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G1
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,265
