跳转到主内容
加入维修社区 - 创建账户
Disassembling Ericsson CF 388 Keypad
你所需要的
  1. Disassembling Ericsson CF 388 Keypad, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 1,3 Disassembling Ericsson CF 388 Keypad, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 2,3 Disassembling Ericsson CF 388 Keypad, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 3,3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
    询问修复机器人
  2. Disassembling Ericsson CF 388 Keypad, Phone Casing: 步骤 2 中的图像 1,3 Disassembling Ericsson CF 388 Keypad, Phone Casing: 步骤 2 中的图像 2,3 Disassembling Ericsson CF 388 Keypad, Phone Casing: 步骤 2 中的图像 3,3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
    询问修复机器人
  3. Disassembling Ericsson CF 388 Keypad: 步骤 3 中的图像 1,3 Disassembling Ericsson CF 388 Keypad: 步骤 3 中的图像 2,3 Disassembling Ericsson CF 388 Keypad: 步骤 3 中的图像 3,3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
    询问修复机器人
  4. Disassembling Ericsson CF 388 Keypad: 步骤 4 中的图像 1,2 Disassembling Ericsson CF 388 Keypad: 步骤 4 中的图像 2,2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
    询问修复机器人
  5. Disassembling Ericsson CF 388 Keypad, Keypad Support Skeleton: 步骤 5 中的图像 1,2 Disassembling Ericsson CF 388 Keypad, Keypad Support Skeleton: 步骤 5 中的图像 2,2
    • After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
    询问修复机器人
  6. Disassembling Ericsson CF 388 Keypad: 步骤 6 中的图像 1,3 Disassembling Ericsson CF 388 Keypad: 步骤 6 中的图像 2,3 Disassembling Ericsson CF 388 Keypad: 步骤 6 中的图像 3,3
    • To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen.
    • Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
    询问修复机器人
  7. Disassembling Ericsson CF 388 Keypad, Keypad: 步骤 7 中的图像 1,2 Disassembling Ericsson CF 388 Keypad, Keypad: 步骤 7 中的图像 2,2
    • To remove the keypad, tilt the phone and the keypad will slide out with the orientation shown.
    询问修复机器人
结论
团队
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G1
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 44
总计 1,186
