跳转到主内容
Disassembling Ericsson CF 388 Circuit Board
你所需要的
  1. Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 1,3 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 2,3 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 步骤 1 中的图像 3,3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 步骤 2 中的图像 1,3 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 步骤 2 中的图像 2,3 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 步骤 2 中的图像 3,3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Circuit Board: 步骤 3 中的图像 1,3 Disassembling Ericsson CF 388 Circuit Board: 步骤 3 中的图像 2,3 Disassembling Ericsson CF 388 Circuit Board: 步骤 3 中的图像 3,3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Circuit Board: 步骤 4 中的图像 1,2 Disassembling Ericsson CF 388 Circuit Board: 步骤 4 中的图像 2,2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
  5. Disassembling Ericsson CF 388 Circuit Board, Circuit Board: 步骤 5 中的图像 1,1
    • Locate the circuit board on the rear side of the front phone casing (right side of image).
    • Locate the mounting screws (indicated by red circles), which attach the board to the rear side of the front phone casing.
  6. Disassembling Ericsson CF 388 Circuit Board: 步骤 6 中的图像 1,3 Disassembling Ericsson CF 388 Circuit Board: 步骤 6 中的图像 2,3 Disassembling Ericsson CF 388 Circuit Board: 步骤 6 中的图像 3,3
    • Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws. Hold the back part of the screw with the metal tweezers.
  7. Disassembling Ericsson CF 388 Circuit Board: 步骤 7 中的图像 1,2 Disassembling Ericsson CF 388 Circuit Board: 步骤 7 中的图像 2,2
    • Completely remove the two center screw as shown.
    • Note: the hand not holding the screw driver is holding the back part of the screw and the panel in place.
  8. Disassembling Ericsson CF 388 Circuit Board: 步骤 8 中的图像 1,2 Disassembling Ericsson CF 388 Circuit Board: 步骤 8 中的图像 2,2
    • Locate the final screw at the top of the phone near the antenna, as shown by the red circle.
    • Using the U-shaped screw driver, remove the top screw.
  9. Disassembling Ericsson CF 388 Circuit Board: 步骤 9 中的图像 1,2 Disassembling Ericsson CF 388 Circuit Board: 步骤 9 中的图像 2,2
    • With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
结论
Niccolas Tones
于03/09/12注册
60 声望
创作了9篇指南
团队
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G1
3 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,267
