跳转到主内容
加入维修社区 - 创建账户
Disassembling Dopo Double Power 7 Rear Panel
你所需要的
  1. Disassembling Dopo Double Power 7 Rear Panel, Rear Panel: 步骤 1 中的图像 1,1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Disassembling Dopo Double Power 7 Rear Panel: 步骤 2 中的图像 1,1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Disassembling Dopo Double Power 7 Rear Panel: 步骤 3 中的图像 1,1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Disassembling Dopo Double Power 7 Rear Panel: 步骤 4 中的图像 1,1
    • The rear panel should come completely off.
结论
4等其他人完成本指南。
mike pelosi
于10/30/15注册
682 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 21
总计 678
