跳转到主内容
Disassembling Dell OptiPlex FX170 Case
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Disassembling Dell OptiPlex FX170 Case, Case: 步骤 1 中的图像 1,1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Disassembling Dell OptiPlex FX170 Case: 步骤 2 中的图像 1,2 Disassembling Dell OptiPlex FX170 Case: 步骤 2 中的图像 2,2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Disassembling Dell OptiPlex FX170 Case: 步骤 3 中的图像 1,3 Disassembling Dell OptiPlex FX170 Case: 步骤 3 中的图像 2,3 Disassembling Dell OptiPlex FX170 Case: 步骤 3 中的图像 3,3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Disassembling Dell OptiPlex FX170 Case: 步骤 4 中的图像 1,2 Disassembling Dell OptiPlex FX170 Case: 步骤 4 中的图像 2,2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 50
