跳转到主内容
Disassembling Dell Inspiron One 2020 Back Cover
你所需要的
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: 步骤 1 中的图像 1,3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: 步骤 1 中的图像 2,3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: 步骤 1 中的图像 3,3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: 步骤 2 中的图像 1,3 Disassembling Dell Inspiron One 2020 Back Cover: 步骤 2 中的图像 2,3 Disassembling Dell Inspiron One 2020 Back Cover: 步骤 2 中的图像 3,3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: 步骤 3 中的图像 1,3 Disassembling Dell Inspiron One 2020 Back Cover: 步骤 3 中的图像 2,3 Disassembling Dell Inspiron One 2020 Back Cover: 步骤 3 中的图像 3,3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
结论
28等其他人完成本指南。
Tyler
于06/19/12注册
4,920 声望
创作了16篇指南
团队
TechForce TechForce 的会员
Business
2 名成员
创作了25篇指南
一条评论
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 75
总计 33,887
