跳转到主内容
Disassembling Dell Inspiron Duo Front Cover
你所需要的
  1. Disassembling Dell Inspiron Duo Front Cover, Front Cover: 步骤 1 中的图像 1,2 Disassembling Dell Inspiron Duo Front Cover, Front Cover: 步骤 1 中的图像 2,2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
  2. Disassembling Dell Inspiron Duo Front Cover: 步骤 2 中的图像 1,2 Disassembling Dell Inspiron Duo Front Cover: 步骤 2 中的图像 2,2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
  3. Disassembling Dell Inspiron Duo Front Cover: 步骤 3 中的图像 1,2 Disassembling Dell Inspiron Duo Front Cover: 步骤 3 中的图像 2,2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
结论
2等其他人完成本指南。
Amrit Multani
于07/14/15注册
115 声望
撰写一个指南
团队
UW Tacoma, Team 1-1, Liner SU 2015 UW Tacoma, Team 1-1, Liner SU 2015 的会员
UWT-LINER-SU15S1G1
3 名成员
创作了4篇指南
一条评论
Can I get a broken screen
Daniel Mwangi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 945
