跳转到主内容
加入维修社区 - 创建账户
Disassembling Compaq Mini 110 Speakers
你所需要的
  1. Disassembling Compaq Mini 110 Speakers, Battery: 步骤 1 中的图像 1,2 Disassembling Compaq Mini 110 Speakers, Battery: 步骤 1 中的图像 2,2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Disassembling Compaq Mini 110 Speakers: 步骤 2 中的图像 1,3 Disassembling Compaq Mini 110 Speakers: 步骤 2 中的图像 2,3 Disassembling Compaq Mini 110 Speakers: 步骤 2 中的图像 3,3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Disassembling Compaq Mini 110 Speakers, RAM: 步骤 3 中的图像 1,2 Disassembling Compaq Mini 110 Speakers, RAM: 步骤 3 中的图像 2,2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Disassembling Compaq Mini 110 Speakers: 步骤 4 中的图像 1,1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Disassembling Compaq Mini 110 Speakers, Keyboard: 步骤 5 中的图像 1,2 Disassembling Compaq Mini 110 Speakers, Keyboard: 步骤 5 中的图像 2,2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Disassembling Compaq Mini 110 Speakers: 步骤 6 中的图像 1,2 Disassembling Compaq Mini 110 Speakers: 步骤 6 中的图像 2,2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Disassembling Compaq Mini 110 Speakers: 步骤 7 中的图像 1,2 Disassembling Compaq Mini 110 Speakers: 步骤 7 中的图像 2,2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Disassembling Compaq Mini 110 Speakers: 步骤 8 中的图像 1,2 Disassembling Compaq Mini 110 Speakers: 步骤 8 中的图像 2,2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Disassembling Compaq Mini 110 Speakers, Hard Drive: 步骤 9 中的图像 1,1
    • Remove the three screws holding the panel in place.
  10. Disassembling Compaq Mini 110 Speakers: 步骤 10 中的图像 1,2 Disassembling Compaq Mini 110 Speakers: 步骤 10 中的图像 2,2
    • Pull up on the tab to remove the hard drive.
  11. Disassembling Compaq Mini 110 Speakers, Top Cover: 步骤 11 中的图像 1,1
    • Remove the eight screws that are from the plastic top cover.
  12. Disassembling Compaq Mini 110 Speakers: 步骤 12 中的图像 1,3 Disassembling Compaq Mini 110 Speakers: 步骤 12 中的图像 2,3 Disassembling Compaq Mini 110 Speakers: 步骤 12 中的图像 3,3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
  13. Disassembling Compaq Mini 110 Speakers: 步骤 13 中的图像 1,2 Disassembling Compaq Mini 110 Speakers: 步骤 13 中的图像 2,2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
  14. Disassembling Compaq Mini 110 Speakers, Display Assembly: 步骤 14 中的图像 1,3 Disassembling Compaq Mini 110 Speakers, Display Assembly: 步骤 14 中的图像 2,3 Disassembling Compaq Mini 110 Speakers, Display Assembly: 步骤 14 中的图像 3,3
    • Remove the four screws that keep the bottom of the hinges attached to the base.
  15. Disassembling Compaq Mini 110 Speakers: 步骤 15 中的图像 1,3 Disassembling Compaq Mini 110 Speakers: 步骤 15 中的图像 2,3 Disassembling Compaq Mini 110 Speakers: 步骤 15 中的图像 3,3
    • Pry off the top plastic cover of the display assembly.
    • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
    • There is adhesive tape holding the cover on.
  16. Disassembling Compaq Mini 110 Speakers, Screen: 步骤 16 中的图像 1,3 Disassembling Compaq Mini 110 Speakers, Screen: 步骤 16 中的图像 2,3 Disassembling Compaq Mini 110 Speakers, Screen: 步骤 16 中的图像 3,3
    • Remove the 4 screws keeping the screen on the plastic assembly.
  17. Disassembling Compaq Mini 110 Speakers: 步骤 17 中的图像 1,3 Disassembling Compaq Mini 110 Speakers: 步骤 17 中的图像 2,3 Disassembling Compaq Mini 110 Speakers: 步骤 17 中的图像 3,3
    • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws.
    • The last picture shows the metal connectors that attach it to the display assembly.
  18. Disassembling Compaq Mini 110 Speakers: 步骤 18 中的图像 1,3 Disassembling Compaq Mini 110 Speakers: 步骤 18 中的图像 2,3 Disassembling Compaq Mini 110 Speakers: 步骤 18 中的图像 3,3
    • Detach the cable from the screen. It is connected under the foil flap.
    • The large wire on the back of the screen is for both the webcam and the microphone, as well as the screen.
  19. Disassembling Compaq Mini 110 Speakers, Speakers: 步骤 19 中的图像 1,3 Disassembling Compaq Mini 110 Speakers, Speakers: 步骤 19 中的图像 2,3 Disassembling Compaq Mini 110 Speakers, Speakers: 步骤 19 中的图像 3,3
    • Unscrew the speaker assembly at the bottom of the screen assembly.
结论
Aleksander
于10/05/10注册
276 声望
撰写一个指南
团队
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G2
6 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 35
总计 3,057
