当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Push out the side tabs simultaneously and pull out the old RAM module.
When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
Remove the rubber pads located on the corners of your Compaq Mini.
There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
Remove the three screws in the silver tabs at the back of the keyboard.
These are located at the back of the base under the screen.
Lift the keyboard away from the laptop.
Pry off the top plastic cover of the display assembly.
The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
There is adhesive tape holding the cover on.
Detach the cable from the screen. It is connected under the foil flap.
The large wire on the back of the screen is for both the webcam and the microphone, as well as the screen.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
