跳转到主内容
Disassembling Coby Kyros MID9742 Outer Casing
你所需要的
  1. Disassembling Coby Kyros MID9742 Outer Casing, Outer Casing: 步骤 1 中的图像 1,1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Disassembling Coby Kyros MID9742 Outer Casing: 步骤 2 中的图像 1,1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Disassembling Coby Kyros MID9742 Outer Casing: 步骤 3 中的图像 1,1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
结论
另外一个人完成了本指南。
Ian Swett
于03/11/15注册
597 声望
创作了5篇指南
团队
Colorado Springs, Team 5-3, Panko Spring 2015 Colorado Springs, Team 5-3, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 496
