跳转到主内容
Disassembling Circo Monkey Alarm Clock Clock Face
你所需要的
  1. Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: 步骤 1 中的图像 1,3 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: 步骤 1 中的图像 2,3 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: 步骤 1 中的图像 3,3
    • Grasp the plastic cover and carefully pull straight back so that the clock cover dislodges from its housing.
    • If any additional assistance is required for this step, it is recommended to use the plastic opening tool to help pry the edges of the cover simultaneously or a suction cup if you cannot grip the rim.
  2. Disassembling Circo Monkey Alarm Clock Clock Face: 步骤 2 中的图像 1,1
    • Using your fingers, grasp the point where the hands of the clock meet in the center and pull straight back until they dislodge from the motor.
    • Be sure that you remove all three hands as well as the pin that connects them in this one step. This component should come out as a single piece.
结论
另外一个人完成了本指南。
Devin Gooding
于01/20/15注册
110 声望
撰写一个指南
团队
USF Tampa, Team 19-1, Blackwell Winter 2015 USF Tampa, Team 19-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G1
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 517
