跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Remove all four screws on the side of camera with speaker.
    • Remove all four screws on the side of camera with speaker.
  2. Remove all four screws from side of camera with wristband attachment.
    • Remove all four screws from side of camera with wristband attachment.
  3. Remove all four screws on bottom of camera.
    • Remove all four screws on bottom of camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  4. Once all screws have been removed, gently pry open bottom casing. With tweezers, carefully remove ribbon from LCD screen. Set bottom casing aside.
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  5. Pry apart the top casing using tweezers. Set the top casing aside.
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
结论
2等其他人完成本指南。
Logan
于2011年01月10日注册
311 信誉积分
创作了2篇指南
团队
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G38
4 名成员
创作了13篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,860
