跳转到主内容
Casio Exilim EX-Z850 Outer Case Replacement
你所需要的
  1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
  2. Casio Exilim EX-Z850 Outer Case Replacement: 步骤 2 中的图像 1,3 Casio Exilim EX-Z850 Outer Case Replacement: 步骤 2 中的图像 2,3 Casio Exilim EX-Z850 Outer Case Replacement: 步骤 2 中的图像 3,3
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
  3. Casio Exilim EX-Z850 Outer Case Replacement: 步骤 3 中的图像 1,2 Casio Exilim EX-Z850 Outer Case Replacement: 步骤 3 中的图像 2,2
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
结论
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2等其他人完成本指南。
Logan
于01/10/11注册
313 声望
创作了2篇指南
团队
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G38
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,036
