Disassembling Canon Powershot SD880 Menu Button
简介
转到步骤 1This may need to be removed if the button or scroll wheel is not working.
你所需要的
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove 2 screws from back of camera using screwdriver.
Remove 2 screws holding metal side guard using screwdriver.
Remove the connecting ribbon by pulling it straight out.
另外一个人完成了本指南。
