本指南有最近更改,您可查看未经巡查的最新版本。
简介
The logic board is the brains behind the camera and should be handled delicately.
你所需要的
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
Unplug the green and white plugs that connect the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the tab at the back.
Remove 2 screws(1.75mm) using a screwdriver.
Detach 3 ribbons by pulling up on them. All are on the front of the camera.
