跳转到主内容
Canon Powershot SD880 LCD Display Replacement
你所需要的
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: 步骤 1 中的图像 1,3 Canon Powershot SD880 LCD Display Replacement, Back Cover: 步骤 1 中的图像 2,3 Canon Powershot SD880 LCD Display Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: 步骤 2 中的图像 1,3 Canon Powershot SD880 LCD Display Replacement, LCD Display: 步骤 2 中的图像 2,3 Canon Powershot SD880 LCD Display Replacement, LCD Display: 步骤 2 中的图像 3,3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
结论
Ben Tupas
于01/13/11注册
317 声望
创作了3篇指南
团队
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G3
5 名成员
创作了8篇指南
一条评论
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,307
