简介
This guide will provide you with the necessary direction to disassemble the flash on a Canon Powershot SD880. Before you start, know that the flash device has a few delicate connections and should be handled with care.
你所需要的
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
Unplug the green and white plugs that connect the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the tab at the back.
Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
Disconnect the ribbons that connect the screen to the camera.
Lift the screen off.
Remove two 1.8 mm screws from the back using a Phillips #0 screwdriver to disconnect the metal guard.
To unplug the ribbon at the top of the camera, gently pull it from the plug-in point.
Disconnect the white plug from the red and black wires.
