跳转到主内容
Disassembling Canon PowerShot SD850 IS Case Removal
你所需要的
  1. Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 步骤 1 中的图像 1,3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 步骤 1 中的图像 2,3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 步骤 1 中的图像 3,3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 2 中的图像 1,2 Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 2 中的图像 2,2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Disassembling Canon PowerShot SD850 IS Case Removal, Case: 步骤 3 中的图像 1,2 Disassembling Canon PowerShot SD850 IS Case Removal, Case: 步骤 3 中的图像 2,2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 4 中的图像 1,3 Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 4 中的图像 2,3 Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 4 中的图像 3,3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 5 中的图像 1,2 Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 5 中的图像 2,2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 6 中的图像 1,2 Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 6 中的图像 2,2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 7 中的图像 1,1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Disassembling Canon PowerShot SD850 IS Case Removal: 步骤 8 中的图像 1,1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
结论
3等其他人完成本指南。
Peter Tran
于10/06/10注册
225 声望
创作了6篇指南
团队
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G7
6 名成员
创作了7篇指南
一条评论
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 4,231
