跳转到主内容
Disassembling Canon PowerShot SD800 IS LCD Display
你所需要的
  1. Disassembling Canon PowerShot SD800 IS LCD Display, Back Cover: 步骤 1 中的图像 1,1
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 2 中的图像 1,1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 3 中的图像 1,1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 4 中的图像 1,1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Assembly: 步骤 5 中的图像 1,1
    • Remove 2 2.4mm screws on bottom.
  6. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 6 中的图像 1,1
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 7 中的图像 1,1
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 8 中的图像 1,1
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
  9. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Display: 步骤 9 中的图像 1,1
    • Pry the LCD display out from the four metal clamps.
  10. Disassembling Canon PowerShot SD800 IS LCD Display: 步骤 10 中的图像 1,1
    • To remove the LCD, peel the larger data cable off from the frame.
    • The LCD is glued by its data cable to the back of the LCD frame.
结论
Jeremy Rabaino
于10/10/10注册
135 声望
创作了6篇指南
团队
Cal Poly, Team 20-9, Maness Fall 2010 Cal Poly, Team 20-9, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G9
5 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,844
