跳转到主内容
Disassembling Canon PowerShot SD800 IS Front Cover
你所需要的
  1. Disassembling Canon PowerShot SD800 IS Front Cover, Back Cover: 步骤 1 中的图像 1,1
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS Front Cover: 步骤 2 中的图像 1,1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS Front Cover: 步骤 3 中的图像 1,1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS Front Cover: 步骤 4 中的图像 1,1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS Front Cover, Front Cover: 步骤 5 中的图像 1,1
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  6. Disassembling Canon PowerShot SD800 IS Front Cover: 步骤 6 中的图像 1,1
    • Remove one 2.25mm screw on the bottom of the camera.
  7. Disassembling Canon PowerShot SD800 IS Front Cover: 步骤 7 中的图像 1,1
    • Pull off the front cover.
结论
Jeremy Rabaino
于10/10/10注册
135 声望
创作了6篇指南
团队
Cal Poly, Team 20-9, Maness Fall 2010 Cal Poly, Team 20-9, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G9
5 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 2,628
