当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove 2 screws from each side of the camera (4 total, 0.102 in).
Remove 2 screws from the bottom on the camera (0.138 in).
Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
Gently pull off the front cover.
The plate on the side should come off.
Gently pull off the back cover.
Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
Use the tweezers to lift this ribbon.
Use the tweezers to gently peel this ribbon from the one underneath it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
