跳转到主内容
Disassembling Canon PowerShot SD1100 IS LCD screen
你所需要的
  1. Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: 步骤 1 中的图像 1,2 Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: 步骤 1 中的图像 2,2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 2 中的图像 1,3 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 2 中的图像 2,3 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 2 中的图像 3,3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 3 中的图像 1,3 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 3 中的图像 2,3 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 3 中的图像 3,3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 4 中的图像 1,1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: 步骤 5 中的图像 1,2 Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: 步骤 5 中的图像 2,2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 6 中的图像 1,2 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 6 中的图像 2,2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 7 中的图像 1,2 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 7 中的图像 2,2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 9 中的图像 1,3 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 9 中的图像 2,3 Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 9 中的图像 3,3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS LCD screen: 步骤 10 中的图像 1,1
    • The LCD screen should now be removed.
结论
3等其他人完成本指南。
Tyler Grossheim
于01/25/11注册
1,623 声望
创作了6篇指南
团队
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G32
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 3,851
