跳转到主内容
Disassembling Breville BKC600XL Coffee Brewer Head
你所需要的
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: 步骤 1 中的图像 1,3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: 步骤 1 中的图像 2,3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: 步骤 1 中的图像 3,3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: 步骤 2 中的图像 1,1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: 步骤 3 中的图像 1,3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: 步骤 3 中的图像 2,3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: 步骤 3 中的图像 3,3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
结论
另外一个人完成了本指南。
Antonio
于09/26/12注册
120 声望
创作了6篇指南
团队
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G3
4 名成员
创作了6篇指南
2条评论
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - 回复
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 4,141
