简介
This guide explains how to disassemble the Breville BKC600XL coffee brewer head.
  1. Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver. Reminder for reassembly; This bottom piece is first to be screwed back on. Reminder for reassembly; This bottom piece is first to be screwed back on.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  4. Remove the grey plastic casing. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
结论
Antonio
于2012年09月26日注册
73 信誉积分
创作了6篇指南
团队
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G3
4 名成员
创作了6篇指南
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - 回复
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 24
总计 2,882
