跳转到主内容
Disassembling Black and Decker BL3000S Blender Base
你所需要的
  1. Disassembling Black and Decker BL3000S Blender Base, Blender Base: 步骤 1 中的图像 1,2 Disassembling Black and Decker BL3000S Blender Base, Blender Base: 步骤 1 中的图像 2,2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Disassembling Black and Decker BL3000S Blender Base: 步骤 2 中的图像 1,1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Disassembling Black and Decker BL3000S Blender Base: 步骤 3 中的图像 1,2 Disassembling Black and Decker BL3000S Blender Base: 步骤 3 中的图像 2,2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Disassembling Black and Decker BL3000S Blender Base: 步骤 4 中的图像 1,1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Disassembling Black and Decker BL3000S Blender Base: 步骤 5 中的图像 1,1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
结论
另外一个人完成了本指南。
Andrew
于10/04/12注册
209 声望
创作了4篇指南
团队
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G34
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 55
总计 7,669
