跳转到主内容
Disassembling Beats Pill 1.0
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Disassembling Beats Pill 1.0, Removing the Case Screws: 步骤 1 中的图像 1,3 Disassembling Beats Pill 1.0, Removing the Case Screws: 步骤 1 中的图像 2,3 Disassembling Beats Pill 1.0, Removing the Case Screws: 步骤 1 中的图像 3,3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
  2. Disassembling Beats Pill 1.0, Removing Center Cover: 步骤 2 中的图像 1,3 Disassembling Beats Pill 1.0, Removing Center Cover: 步骤 2 中的图像 2,3 Disassembling Beats Pill 1.0, Removing Center Cover: 步骤 2 中的图像 3,3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Disassembling Beats Pill 1.0, Separate the Device: 步骤 3 中的图像 1,3 Disassembling Beats Pill 1.0, Separate the Device: 步骤 3 中的图像 2,3 Disassembling Beats Pill 1.0, Separate the Device: 步骤 3 中的图像 3,3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: 步骤 4 中的图像 1,2 Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: 步骤 4 中的图像 2,2
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: 步骤 5 中的图像 1,2 Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: 步骤 5 中的图像 2,2
    • Carefully remove the black and red NFC sensor wires.
  6. Disassembling Beats Pill 1.0, Disconnect Control Wiring: 步骤 6 中的图像 1,2 Disassembling Beats Pill 1.0, Disconnect Control Wiring: 步骤 6 中的图像 2,2
    • Carefully remove the control cables (4 black, 1 red).
结论
To reassemble your device, simply follow the disassembly guide in reverse. If you have questions or concerns about the disassembly of your device, please see the device page or troubleshooting page for the Beats Pill 1.0 for more information.
5等其他人完成本指南。
团队
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 20
总计 4,441
