跳转到主内容
Disassembling Beaba Lutin night lamp
你所需要的
  1. Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: 步骤 1 中的图像 1,3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: 步骤 1 中的图像 2,3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: 步骤 1 中的图像 3,3
    • The lamp opens up at the base: there are two smaller tabs next to the button, the semi-transparent plasic can be pressed in a bit with a knife, put a bit of paper inbetween to prevent the clip from snapping back. Next go with a knife towards one of the large tabs on the side until one side snaps out. Repeat for other side.
  2. Disassembling Beaba Lutin night lamp: 步骤 2 中的图像 1,3 Disassembling Beaba Lutin night lamp: 步骤 2 中的图像 2,3 Disassembling Beaba Lutin night lamp: 步骤 2 中的图像 3,3
    • Remove the 4 screws (warning: 2x2 different types), out comes the pcb. Detach battery connector at the back.
  3. Disassembling Beaba Lutin night lamp: 步骤 3 中的图像 1,3 Disassembling Beaba Lutin night lamp: 步骤 3 中的图像 2,3 Disassembling Beaba Lutin night lamp: 步骤 3 中的图像 3,3
    • remove two more screws to get at the battery
  4. Disassembling Beaba Lutin night lamp: 步骤 4 中的图像 1,1
    • Overview of parts
结论
5等其他人完成本指南。
petur
于07/23/11注册
508 声望
创作了3篇指南
3条评论
I think it is easier to open the lamp by pressing the semi-transparent part at the opposite side of the button.
Matthieu Morel - 回复
How can I open the lamp??? Please post a photo of how are u using the knife because I can't!!!
Alberto Santaella Gallego - 回复
you need to press the clips inward, the picture shows where the clips are. Slide inbetween and press
petur - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 11
过去 30 天: 56
总计 3,487
