你所需要的
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
Unscrew the 2 4 mm Phillips head screws by the battery.
Place your fingers or a spudger between the front panel and the rest of the laptop.
Pull upwards gently to detach the side you are grabbing.
Repeat on the other side until the panel easily peels off the laptop.
结论
