跳转到主内容
加入维修社区 - 创建账户
Disassembling Asus Eee PC 1000HE Lower Assembly
你所需要的
  1. Disassembling Asus Eee PC 1000HE Lower Assembly, Lower Assembly: 步骤 1 中的图像 1,1
    • Turn off the power and remove the battery before working on your Eee PC
    • Start by removing the keyboard
    • There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
    • You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
    • The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
    • Caution: the keyboard has a ribbon connector underneath it which must be carefully unplugged before fully removing the keyboard.
  2. Disassembling Asus Eee PC 1000HE Lower Assembly: 步骤 2 中的图像 1,2 Disassembling Asus Eee PC 1000HE Lower Assembly: 步骤 2 中的图像 2,2
    • 7 screws hold the front plate to the motherboard, as well as the ones on the rear of the PC.
    • Before taking off the case, you need to disconnect the touchpad and hotkeys cables.
结论
另外一个人完成了本指南。
adammw
于01/21/11注册
111 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 21
总计 3,329
