跳转到主内容
Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
你所需要的
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: 步骤 1 中的图像 1,3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: 步骤 1 中的图像 2,3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: 步骤 1 中的图像 3,3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 2 中的图像 1,2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 2 中的图像 2,2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 3 中的图像 1,1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 4 中的图像 1,2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 5 中的图像 1,3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 5 中的图像 2,3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 5 中的图像 3,3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 6 中的图像 1,3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 6 中的图像 2,3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: 步骤 6 中的图像 3,3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
结论
Kue
于03/18/15注册
301 声望
创作了3篇指南
团队
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G2
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 433
