跳转到主内容
Disassembling Apple IIc Cover
你所需要的
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: 步骤 1 中的图像 1,2 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: 步骤 1 中的图像 2,2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Disassembling Apple IIc Cover: 步骤 2 中的图像 1,2 Disassembling Apple IIc Cover: 步骤 2 中的图像 2,2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Disassembling Apple IIc Cover: 步骤 3 中的图像 1,2 Disassembling Apple IIc Cover: 步骤 3 中的图像 2,2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    This step is wrong. The ports cover should be removed with a plastic disassembly tool first. Failure to do this will lead to a set of broken plastic hooks.
    cybernesto - 回复
  4. Disassembling Apple IIc Cover: 步骤 4 中的图像 1,2 Disassembling Apple IIc Cover: 步骤 4 中的图像 2,2
    • Lift the handle straight up to remove.
结论
10等其他人完成本指南。
团队
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G23
4 名成员
创作了13篇指南
3条评论
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - 回复
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III -
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 57
过去 30 天: 92
总计 9,618
