跳转到主内容
加入维修社区 - 创建账户
Disassembling Apple AirPort Extreme Base Station Model A1034
你所需要的
  1. Disassembling Apple AirPort Extreme Base Station Model A1034, Disassembling Apple AirPort Extreme Base Station Model A1034: 步骤 1 中的图像 1,1
    • Remove the three 5mm T7 Torx screws from the back panel.
    询问修复机器人
    添加评论
  2. Disassembling Apple AirPort Extreme Base Station Model A1034: 步骤 2 中的图像 1,1
    • Remove one 5mm phillips screw located under the identification sticker. You will need to remove the sticker or make a hole to get to the screw.
    询问修复机器人
    添加评论
  3. Disassembling Apple AirPort Extreme Base Station Model A1034: 步骤 3 中的图像 1,1
    • Separate the bottom and top casings.
    询问修复机器人
    添加评论
  4. Disassembling Apple AirPort Extreme Base Station Model A1034: 步骤 4 中的图像 1,2 Disassembling Apple AirPort Extreme Base Station Model A1034: 步骤 4 中的图像 2,2
    • Remove the metal case from the top case of the AirPort, there are no screws holding it on.
    • Remove the four screws from the metal casing.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G15
3 名成员
创作了13篇指南
1指南评论
Whoa, who’d have thought there was a hidden 5mm phillips under the serial number that does the trick? I’ve had this little beauty hanging around for decades, and my six year old started using it as a flying saucer with his lego creations, and it took me three months of pandemic before I picked up my screwdrivers and tried to take it apart so that he could really use it. For now it’s just empty, and he closes some figures in it with a rubber band and flies it around. Someday I’ll get that dremel i’ve wanted and make him some sort of hatch and latch for it, maybe add some lego baseplate bits to it or something, it can join the rebel alliance for reals.
bitfool - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 88
总计 3,715
