跳转到主内容
Disassembling Acer Iconia A1-830 Back Panel
你所需要的
  1. Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: 步骤 1 中的图像 1,2 Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: 步骤 1 中的图像 2,2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Disassembling Acer Iconia A1-830 Back Panel: 步骤 2 中的图像 1,2 Disassembling Acer Iconia A1-830 Back Panel: 步骤 2 中的图像 2,2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
结论
10等其他人完成本指南。
Matt Champagne
于10/20/15注册
458 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G6
3 名成员
创作了5篇指南
2条评论
Hi iv got an acer icon is one 10.iv done a factory reset ,but it hasent come back ,and it turns on but I can't stop it talking ,volume won't turn down and ,when I checked the volume button it says it turn off .the tablet won't do anything .can you tell me if it's worth repairing and how much if possible. Thank you Teresa spry
Teresa Spry - 回复
Can the back of the tablet be completely removed, so i can look at the micro USB port, to see if that is what is not letting the tablet charge !! Without not knowing what I’m doing and messing it up!!
andre_chatel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 6,040
