跳转到主内容
Removing DVD Drive from Acer Aspire 5100
你所需要的
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: 步骤 1 中的图像 1,2 Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: 步骤 1 中的图像 2,2
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: 步骤 2 中的图像 1,1
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: 步骤 3 中的图像 1,2 Removing DVD Drive from Acer Aspire 5100: 步骤 3 中的图像 2,2
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: 步骤 4 中的图像 1,2 Removing DVD Drive from Acer Aspire 5100: 步骤 4 中的图像 2,2
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: 步骤 5 中的图像 1,1
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
结论
To reassemble, follow above steps in reverse.
2等其他人完成本指南。
luis
于04/21/10注册
167 声望
撰写一个指南
团队
Cal Poly, Team 18-66, Johann Spring 2010 Cal Poly, Team 18-66, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G66
5 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 2,797
