跳转到主内容
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
你所需要的
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: 步骤 1 中的图像 1,2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: 步骤 1 中的图像 2,2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 步骤 2 中的图像 1,3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 步骤 2 中的图像 2,3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 步骤 2 中的图像 3,3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: 步骤 3 中的图像 1,1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
结论
8等其他人完成本指南。
Efe Guldogan
于08/26/15注册
860 声望
创作了4篇指南
团队
USF Tampa, Team 14-23, Meier Fall 2015 USF Tampa, Team 14-23, Meier Fall 2015 的会员
USFT-MEIER-F15S14G23
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 44
总计 13,631
