跳转到主内容
Disassembling ASUS K501U
你所需要的
  1. Disassembling ASUS K501U, ASUS K501U: 步骤 1 中的图像 1,1
    • Place as shown in the photo with the screen hinge at the top. Remove all ten screws from the bottom cover. These screws have different length - longest at the top and shortest at the bottom. I color-coded screws with similar length in red, yellow and green. Make sure to install them correctly when you assemble the laptop back together.
    • Remove the four 10.7mm-long screws along the top edge.
    • Remove the two 6.7mm-long screws along the sides.
    • Remove the four 4.7mm-long screws along the bottom edge.
  2. Disassembling ASUS K501U: 步骤 2 中的图像 1,1
    • The bottom cover is held in place by plastic tabs along the outside edges. Using a plastic pry tool, carefully separate the bottom cover from the palmrest assembly and remove it.
  3. Disassembling ASUS K501U: 步骤 3 中的图像 1,1
    • The battery is connected to the motherboard via a cable.
    • Remove the four 4.7mm-long screws securing the battery.
  4. Disassembling ASUS K501U: 步骤 4 中的图像 1,1
    • In order to unlock the battery connector you’ll have to slide the metal bracket to the shown direction.
  5. Disassembling ASUS K501U: 步骤 5 中的图像 1,1
    • Carefully lift up the battery cable from the connector.
    • Do not use metal objects to lift up the cable. You can short metal pins inside. It is recommended that you use a plastic spudger.
  6. Disassembling ASUS K501U: 步骤 6 中的图像 1,1
    • You can find a new replacement battery using the part number printed on the original battery. I would recommend using a genuine Asus battery, not a third-party replacement. Replacement battery model B31N1429.
  7. Disassembling ASUS K501U: 步骤 7 中的图像 1,1
    • Asus K501U motherboard has only one memory slot. Some memory is built into the motherboard. You can access the available slot if you remove the metal cover. You can install up to 8GB DDR3-12800 SODIMM RAM module into this slot.
  8. Disassembling ASUS K501U: 步骤 8 中的图像 1,1
    • Remove four 4.7mm-long screws from the hard drive caddy and remove the caddy. This laptop came with a m.2 solid state drive so there is no regular 2.5″ hard drive installed.
  9. Disassembling ASUS K501U: 步骤 9 中的图像 1,1
    • Remove one screw securing the solid state drive and pull the drive out. This is m.2 SATA III solid state drive (not NVMe).
  10. Disassembling ASUS K501U: 步骤 10 中的图像 1,1
    • Remove three screws securing the right fan.
    • Disconnect fan cable from the motherboard.
  11. Disassembling ASUS K501U: 步骤 11 中的图像 1,1
    • Remove the right fan.
  12. Disassembling ASUS K501U: 步骤 12 中的图像 1,1
    • Remove three screws securing the left fan.
  13. Disassembling ASUS K501U: 步骤 13 中的图像 1,1
    • Remove the left fan.
  14. Disassembling ASUS K501U: 步骤 14 中的图像 1,1
    • The USB audio board is mounted under the right hinge.
    • Remove three screws from the right hinge. Remove one screw from the board.
    • Disconnect the USB audio board cable (color-coded in green).
    • Disconnect the right speaker cable (color-coded in yellow).
  15. Disassembling ASUS K501U: 步骤 15 中的图像 1,1
    • Unlock the connector first by lifting up the locking tab.
    • After that pull the cable out.
  16. Disassembling ASUS K501U: 步骤 16 中的图像 1,1
    • Lift up the right hinge and remove the USB audio board.
  17. Disassembling ASUS K501U: 步骤 17 中的图像 1,1
    • Carefully disconnect wireless antenna cables from the wireless card.
  18. Disassembling ASUS K501U: 步骤 18 中的图像 1,1
    • Remove one 4.7mm-long screw securing the wireless card.
    • Pull out the wireless card in the direction shown.
结论
另外一个人完成了本指南。
tqd
于04/09/25注册
3,182 声望
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 141
总计 992
