简介
Follow this guide to remove the board that contains both joystick modules. Removing the board let's you solder new modules or clean them.
你所需要的
With an opening pick, detach the seven clips holding the faceplate. Start from the sides, towards the bottom.
Detach the remaining clips by carefully raising the faceplate away from the clips.
Move the faceplate to the side.
Slowly lift the board from the controller. Make sure to lift both rumble motors as well.
结论
